Author Topic: Serpentine Swap  (Read 7450 times)
Offline jdmaffeo
Serpentine Swap
« on: November 18, 2005, 04:46:00 pm »
Have any of you guys ever swapped out your v-groove pulley systems for a serpentine setup?  If so what all is involved?  I am looking at doing this.  I know that the a/c compressor and alternator must be swapped, but I am not sure what else might be involved.  I have a 84 stepside with a 305 and a 4 speed transmission.  Thanks!
Offline roundedline
Re: Serpentine Swap
« Reply #1 on: November 18, 2005, 08:28:00 pm »
Basically you need the complete frontend off a 88-up truck.  Including the water pump as it spins in a different direction.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 85chevy
Re: Serpentine Swap
« Reply #2 on: November 18, 2005, 08:33:00 pm »
I reused the power steering pump, but had to use the serpentine pulley. Everything else I had to get from a newer truck or buy new. Your best bet is to find a donor truck in a junk yard and use the accessories off it as cores.
Offline jdmaffeo
Re: Serpentine Swap
« Reply #3 on: November 20, 2005, 06:47:00 pm »
Thanks for the information!
