Author Topic: SBC to BBC swap  (Read 4698 times)
Offline Bigwayne
SBC to BBC swap
« on: August 06, 2017, 07:11:16 pm »
New guy here, I can't seem to find anything on this in a search, I have a 86 GMC 2wd, I'm putting a 496 in it, need some help with motor mounts, some say the SB mounts will work or is there a BB mount I have to get, also does anyone know what headers will fit, and what radiator will work for the BB, and last, what about the water pump long or short thanks
Offline Engineer
Re: SBC to BBC swap
« Reply #1 on: August 07, 2017, 04:48:58 pm »
You want the 4 core radiatior. Standard equipment for the BB equipped trucks.
Hooker headers.
Long water pump. Brackets are way easier to find.
SB mounts will work but I had an issue with my HD 7 blade fan rubbing the lower side of the fan shroud on my 4x4. BB mounts are taller and centers the fan in the shroud opening.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Bigwayne
Re: SBC to BBC swap
« Reply #2 on: August 09, 2017, 02:13:48 am »
Thanks, what year and size truck did they start putting BB in these trucks, I found all the brackets an pulleys at Alan grove components,
Offline Engineer
Re: SBC to BBC swap
« Reply #3 on: August 10, 2017, 08:12:27 pm »
The 454 I have in my monster truck is out of a '73 C-20.
Re: SBC to BBC swap
« Reply #4 on: August 11, 2017, 07:39:33 am »
BB came in ½tons for certain years also
Offline Bigrig
Re: SBC to BBC swap
« Reply #5 on: August 11, 2017, 10:41:38 am »
I am doing a similar swap except I went with a 455 Oldsmobile (torque monster) and am had header clearance issues and had to add a 1/2 spacer  for the motor mount which I fabricated to get the clearance , not a big deal
Long Bed low and fast
