Author Topic: Dump the Pump?  (Read 3650 times)
Offline rameye
Dump the Pump?
« on: August 07, 2017, 09:12:41 am »
I was querying my local inspector/mechanic about my new wreck (1987 V-10) and he said in my area, after 20 years there is no emission requirement, they dont look, dont care, told me I could pretty much go hog wild.
 I did some searches on this board about removing the smog crap.
Still have some unanswered questions--
 If I go for some shorty headers with an 02 sensor bung welded in..will the computer post a code??
 Does the computer monitor the smog pump or anything else in the system that it would trip??
 Any other pit falls??
 I plan on keeping the parts handy..got the belt situation figured out..  Im assuming the 02 sensor will tune the TBI accordingly
 Many Thanks
Modify message
Report
Re: Dump the Pump?
« Reply #1 on: August 08, 2017, 12:41:47 pm »
If you are keeping the TBI you need the 02, it uses that to keep the fuel mixture accurate.
Offline rameye
Re: Dump the Pump?
« Reply #2 on: August 08, 2017, 02:13:11 pm »
Thanks Chris..yeah I plan on keeping the TBI-- always been a rock solid unit---
Just didnt know if the computer would post a code trying to turn on the pump, look for pump output pressure,  or actuate a relay valve downstream...find it missing... and post a code
Thanks for the reply
