Engine/Drivetrain
Rear Drivelines, Drive Axles and Gearing
12 bolt or 10 bolt??
Topic: 12 bolt or 10 bolt?? (Read 13076 times)
cooltoolguy
November 25, 2005, 06:06:00 pm »
i just pick up a 76 c-10 to part out with a 12 bolt rear, not sure of gear ratio yet. now the 86 has a 10 bolt and i have an 84 with a 10 bolt. question is... what is the difference between a 12 bolt and a 10 bolt and what would be better to use in a build up (more hp from engine) any help greatly appreciated. thanks steve
roundedline
Re: 12 bolt or 10 bolt??
November 25, 2005, 05:33:00 pm »
The difference is the 12bolt is stronger. It has a 8.875" ring gear versus a 8.5" ring gear on the 10bolt.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
Blazin
Blazin new trails!
November 29, 2005, 06:24:00 am »
The other difference is the U Joint size, the cap diamiter is if I remember corectly smaller on the 12 bolt yoke, and the length of the cross is also different. You can get a jont with both dimensions for this aplication.
cooltoolguy
November 29, 2005, 08:13:00 pm »
thanks for the info. there is a local shop who makes there own driveshafys, yokes , cap etc. the guy i got the truck from took the engine, trans, drive shaft and cap too.
Engine/Drivetrain
