Author Topic: Wounded 350  (Read 7689 times)
Offline 1976Scottsdale
Wounded 350
« on: December 04, 2005, 03:50:00 pm »
1978 Chevrolet
K-10
350 sbc
Had the truck warming up before school the other morning and when I got to school, the temp was pegged.  The water pump had quit flowing.  Towed the truck home and finally got the thing fixed and put back together at 2:00 AM this morning.  New 180 thermostat, new Signature Series brand water pump, new timing set, balancer, timing cover, oil pan, and bearings(rods and mains and rear main seal) and HV oil pump).  The trck had been leaking oil so I fixed it all.  Anyway, started the truck, it warmed up, but missed on two cylinders, drove it for 5 minutes or so and it heated up to 230 degrees.  Got out and looked at the exhaust, driver side was okay, passenger side could fog out a city block.  So, the 993 heads are junk now, water in oil, most likely cracked a head, so now the 601 heads that are supposed to be going on my 350 project for next spring will now be going on the 350 in my truck.  Hopefully the block and rotating assembly is still good.  Otherwise it will be time to sell the truck.  That would be upsetting.
Offline kursed
    • Chopperhack
Re: Wounded 350
« Reply #1 on: December 04, 2005, 09:01:00 pm »
i would still have em magnafluxed, could have just been a blown head gasket.. think positive right?
Re: Wounded 350
« Reply #2 on: December 04, 2005, 09:58:00 pm »
I was thinking along those same lines right up until I saw that one of them had a visible crack in the combustion chamber.  My dad and I decided that the whole engine is coming out and is going to be used to rebuild and sell to a gentleman who want to convert his 66 1/2 ton chevy to a 350 fram a 230.  I am going to build my 350 4 bolt project with the money I make from building the engine.
Offline kursed
    • Chopperhack
Re: Wounded 350
« Reply #3 on: December 04, 2005, 11:43:00 pm »
ouch, sorry bout the luck, but at least you have a plan set allready
