Author Topic: Rear cab seam shave  (Read 3455 times)
Offline Redz
  • If you build something build it right
Rear cab seam shave
« on: August 14, 2017, 10:57:55 pm »
In the next couple of weeks I am wanting shave the rear cab seam. Has anyone done this that could give me some advice in the process of doing this.
Offline square81
Re: Rear cab seam shave
« Reply #1 on: August 16, 2017, 07:14:16 pm »
Im interested in doing that too. Ive seen guys fill it bondo or spot weld and grind.
Offline Redz
« Reply #2 on: August 16, 2017, 07:26:15 pm »
Well I am going to weld mine I don't want the cab to flex and crack the filler. I have heard that you need to be careful because there is not many welds holding that seam together and it's glued/seam sealer from the factory but this is what I've heard. Not always true. I will find out in a few weeks. It's nice to know I'm not the only one that thinks this is a awesome mod cleans the back of the cab up real good 8)
