Author Topic: passenger side fuel sending unit  (Read 11349 times)
Offline mrboyy17
« on: August 15, 2017, 09:39:26 pm »
So I pulled my tank to replace the sending unit on passenger side.  It has 2 ports attached to fuel lines.  When I am looking at replacements, most have 3 prongs....what is the third prong for?
I have a 6.2 diesel motor that is 1986.
Should I just find a 350 motor sending unit that is 2 prong and replace / call it good? or should I replace with the 3 prong "original" type sending unit?
what does the 3rd prong supposed to be going to?
thanks all
Mark
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: passenger side fuel sending unit
« Reply #1 on: August 16, 2017, 04:59:14 am »
Third prong is vapor line to a charcoal canister for gas engines, you can plug that line.
Make sure you get the diesel specific in tank sock if you use an in tank sock- a gas sock/strainer will literally stop fuel flow. I'll find the part number for you.
 1986 Chevy K30(under repair)
« Reply #2 on: August 16, 2017, 05:07:55 am »
Fuel tank sock/strainer: AC-DELCO TS1012
Offline mrboyy17
« Reply #3 on: August 16, 2017, 07:58:18 am »
thanks Kaiser,
it appears as if the sending units come with a sock.  I guess the best course of action is to get the diesel specific sending unit (which should have the right sock on it) and plug the third outlet.
thanks for the reply!
Offline mrboyy17
« Reply #4 on: August 16, 2017, 08:35:32 am »
anyone have a part number for me to get for this?
