Author Topic: Are all th400 transmissions the same?  (Read 7933 times)
Offline ih8mud
« on: December 06, 2005, 06:45:00 pm »
I am considering swapping my th350 for a th400.  I have a np203 transfer case.  I have located an adapter for mating a th400 to a np203 transfer case.  My question is will any th400 work.  Just curious if there is an difference between the 2wd and the 4wd.  I've heard that there is a difference in the length of the output shaft.  I have a 79 chevy long bed pickup truck.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #1 on: December 06, 2005, 05:49:00 pm »
Indeed the size of the transmissions on 4x4's are different.  The shaft length is different (shorter for the 4x4's).
SgtDel
Offline roundedline
Re: Are all th400 transmissions the same?
« Reply #2 on: December 06, 2005, 05:56:00 pm »
4WD transmissions are lacking the tailhousing that 2WD tranny has.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #3 on: December 07, 2005, 11:24:00 am »
Not sure about the TH 400s and a 203, but I have a two wheel drive short shaft TH350 mated to a 208 case in my Blazer. I had to remove the tail shaft housing and cut about an 1 1/2" off the output shaft.
