Author Topic: A/c creates high idle  (Read 6376 times)
Offline Spoonbill
« on: August 21, 2017, 06:41:30 pm »
So I was sitting the driveway reading some emails and I turned on the a/c and the idle went double as to what it was before I turned the a/c on. It has never done this before. What would cause this to happen????
Re: A/c creates high idle
« Reply #1 on: August 21, 2017, 07:06:50 pm »
Misadjusted idle speed solenoid.
Offline Spoonbill
« Reply #2 on: August 21, 2017, 07:58:01 pm »
That would make it just all of a sudden? Please remember it has only 66,000 original documented miles and all the parts are original except for the tune up I did last November
Offline Spoonbill
« Reply #3 on: August 21, 2017, 08:08:11 pm »
Is this also called iac valve??
« Reply #4 on: August 21, 2017, 08:13:54 pm »
Provide the year, make, model of the truck and the engine/transmission combination.
Offline Spoonbill
« Reply #5 on: August 21, 2017, 10:50:41 pm »
I just put a new iac valve on about 3 months ago. Truck is an 87 r10 305tbi 700r4
« Reply #6 on: August 21, 2017, 11:11:44 pm »
Is the amber Service Engine Soon light coming on?  Are there any stored trouble codes?  Does the A/C work?
Offline Spoonbill
« Reply #7 on: August 22, 2017, 02:35:05 pm »
No warning lights have ever came on. A/c works awesome, it is still the original r-12 one that came on it. It is expensive but well worth it cause it so much colder than 134. To check for codes could I just take it up to autozone and have them hook that hand held scanner up to it?
« Reply #8 on: August 22, 2017, 03:19:17 pm »
That would be a good starting point.  Or, you can retrieve any stored codes yourself using a paperclip; see OBD I code retrieval and decoding.
Does the service engine soon (SES) dash lamp illuminate when you switch on ignition, before starting the engine?
Do you have a digital volt ohmmeter?
« Last Edit: August 22, 2017, 04:21:48 pm by bd »
« Reply #9 on: August 22, 2017, 03:58:57 pm »
You should also begin to familiarize yourself with the 1987 Light Duty Truck Fuel, Drivability and Emissions manual.  It is an invaluable, essential tool.
Offline Spoonbill
« Reply #10 on: August 23, 2017, 08:50:09 pm »
Yes it comes on before I start the truck but as soon as started it goes out. I don't know anything about this stuff yet, I'm still in the learning phase so I will let autozone get the codes for me so that I will know it was right
