Author Topic: NP241 passenger drop identification and wiring  (Read 10036 times)
Offline MuddiGGEr25
  • Wrencher
« on: September 02, 2017, 09:04:03 am »
I've had a real hard time coming up with much or any info on the np241 passenger side drop tcase. The gm literature says this burb has a 700r4 ( 27 spline) and np241. Its a 1991 v1500 with a 350 and 3.73 gear ratio.  I have attached a pic of the tail housing for the tcase and it appears to have a speed sensor which I can use for my 1995 tbi 454ss so it can have its normal input for shift points. Can anyone help me verify this? I don't have the DRAC module wiring, but from another post I had the diagram says the tcase speed sensor splits to the speedo and cruise control and the original signal is passed to the PCM or TCM. I don't have an electronic speedo or electronic cruise so I just need to know if I can fee that signal to my PCM
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Offline MuddiGGEr25
  • Wrencher
Re: NP241 passenger drop identification and wiring
« Reply #1 on: September 02, 2017, 09:08:08 am »
Here's the pic
« Reply #2 on: September 02, 2017, 08:24:58 pm »
i want to say yes, cant say for sure. But i can tell you they used the same sensors from 88-99. i dont see why not since 95 was the last year of the tbi and pretty much the same setup as 91
Offline MuddiGGEr25
  • Wrencher
« Reply #3 on: September 03, 2017, 12:10:13 pm »
well i got under there, and started disassembly (my God there is a ton of rust), anyway i looked up the speed sensor for a 1991 V1500 5.7L/700r4 suburban and the part no was the same for a 1995 K2500 7.4L/4l80E TBI setup, so the signal will be the same, i just have to find which of the 2  connectors i need to plug it into, as both of them had the same connector but i dont know which one goes where i needed it to, so ill have to scrape up those wiring diagrams again
« Reply #4 on: September 03, 2017, 03:11:04 pm »
might be able to tell by which wires are longer? or have a kink in from that bend?
