Author Topic: In need of an Speed Sensor!!!  (Read 6651 times)
Offline ih8mud
« on: December 25, 2005, 06:56:00 pm »
I have a 79 chevy 4x4 with a 350, attached to a th350 with the np203.  Ever sence i have bought the truck i have never known how fast i am going.  Now with the 350 bored and rebuilt it has a little more get up and go.  I need an speed sensor off and np203.  I think that is what it is called.  It is bolted to the transfer case and the speedometer is attached to it.  If any one knows where i could get one.  Could you please tell me.  Thank you.
Offline 1976Scottsdale
Re: In need of an Speed Sensor!!!
« Reply #1 on: December 29, 2005, 07:26:00 pm »
You should be able to just install the speedo cable and be fine, that is how mine is and all it does is bounce a little.  Mine had the same thing, ended up needing both a speedo cabe and a speedometer.  Go to Autozone and look for the speedo cable from a 1978 Chevrolet K-10 without cruise, they will show 3 different ones or so, ask for the longest one and use it, it is like 100 inches or so.  That is what I am running now, the slightly shorter one will break as you would have to bend it to get it to fit at all.  The cable will run you about $13.00 or so.
