Author Topic: Live wire in engine compartment ID  (Read 4980 times)
Offline bennydog
« on: September 17, 2017, 05:18:25 pm »
I have a hot wire connection coming through a wire loom that has 2 wires one is green and is connected to the head looks to be a temp, The other is a brown with a female connection that has nowhere to go. any ideas?  Edit, This is a 1975 C10 SWB Cheyenne with a 350/350 combo. Has oil pressure, water temp and amp gauges... speedo and fuel also. Thnaks
« Last Edit: September 17, 2017, 07:20:16 pm by bennydog »
Re: Live wire in engine compartment ID
« Reply #1 on: September 17, 2017, 05:45:19 pm »
maybe oil pressure switch
to help out more
When posting a question Please include the year, make, model, drivetrain configuration at a MINIMUM and all applicable info that is relative to the question.  This will help everyone here help you better if we know what you are working on and what your end goal is.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=34547.0
Offline bennydog
« Reply #2 on: September 17, 2017, 07:25:31 pm »
updated make model ect. Thanks
« Reply #3 on: September 17, 2017, 09:35:51 pm »
The green is engine coolant temp sender.  The "brown" is actually tan and is supposed to connect to an idle stop solenoid on the carburetor.
Offline bennydog
« Reply #4 on: September 18, 2017, 01:33:37 pm »
Thank you!
Online Rapid Roy
  • Euless, Texas
« Reply #5 on: September 18, 2017, 01:48:38 pm »
I have the same wire on my 74. Green is for temp sensor and the brown is for something else, not sure. It is hot all time key is on. In fact, it fell onto manifold and blew fuse for radio so I'm not sure what it goes to. I have an idle stop solenoid on mine that I connected to AC clutch hot wire so it is only energized when AC is on.
Mopar by Birth
Chevy by Choice
