Author Topic: Exhaust leak causing engine to run rough?  (Read 3041 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: September 23, 2017, 07:43:52 pm »
I have a 1974 chevy C10 1/2 ton (ok redundant I know), chevy stepside.  350 with what I was told is a 450 transmission.  Not sure on that...but..the truck developed an exhaust leak on the way home (within a few miles of home).  Seems to run rough as well and it may well be that when replace the flange gasket or doughnut gasket, (manifold to exhaust pipe), the whole problem clears up.  The leak seems to have the whole truck shaking.  Anyway, I will pull the exhaust pipe tomorrow.  I Soaked the bolts with penetrating oil today to try and loosen them a bit before I pull them.  I hate exhaust problems. If this doesn't go easy I will head to the muffler shop!!  Anybody seen an exhaust leak cause a rough idle??
Ricky
Offline blazer74
Re: Exhaust leak causing engine to run rough?
« Reply #1 on: September 24, 2017, 05:07:31 am »
Something else going on like maybe a burn't plug wire or bad plug for starters.
