Author Topic: 383 Stroker Engines  (Read 7204 times)
Offline 86GMC4x4
383 Stroker Engines
« on: December 18, 2005, 01:59:00 pm »
Hello I have been cruising around on this board as a guest for a while and finally signed up today. I have a 86 GMC 4x4 with a 350 engine and TH400 tranny and a 84 SWB Chevy with a 305 and TH700R Tranny.
I have a question I would like to ask.I would like to put a 383 stroker engine in my 86, but was wondering if it is possible to use the exsisting block, the block only has 2 bolt mains.The primary use of the truck would be  used as a daily driver with limited off road use and very little towing at this time.
Any information would be greatly appreciated
Thanks
Edited by: 86GMC4x4 at: 12/18/05 2:27 pm
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
383 Stroker Engines
« Reply #1 on: December 18, 2005, 10:30:00 pm »
Absatootely
A 383 is made from a 350 block, whether it be a 2 bolt or 4 bolt main--no matter.  Some would say a 2 bolt is just as good as a 4 bolt unless you're racing or something.  It'll be just fine.
Get yourself a 400 ci crank, balancer, and flywheel or flexplate. Add all the ingredients and bake at 383 degrees for a hundred thousand miles.
You can get the 383 stroker kits w/ pre-grinided connecting rods (PAW or Summit or jegs), just bore that block 30 over and put that joker together.
You'll have loads of torque.  You may need to replace your rear tire rubber quite frequently though.
My 383 Stoker Stump Puller
Good Luck
SgtDel
Edited by: SgtDel at: 12/18/05 10:32 pm
Offline H A REDNECK
Re: 383 Stroker Engines
« Reply #2 on: December 22, 2005, 10:31:00 am »
yes. I agree with SgtDel the kits from Summit or Jeg,s are the way to go. I would also get  ARP main cap and rod bolt kits.
Offline RSBAD454
« Reply #3 on: January 07, 2006, 12:19:00 pm »
I plan on building a 383 for my 91 chevy truck......can't go wrong with more leverage.8)
Toys are my game
http://
