Author Topic: Wiring issues  (Read 4508 times)
Offline Golf
Wiring issues
« on: October 04, 2017, 01:31:07 am »
1984 c10 custom deluxe. 305
No dash illumination
Left turn signal indicator lights up constant and dims with headlight switch
Right turn signal indicator blinks along with one dim blinking bulb at climate control
Aftermarket gauges light up using dash light fuse so headlight switch works, fuse good.
Turning on headlights makes gauges stop working as in no oil pressure, fuel reading, volts...
On the outside all turn signals function except passenger front. The front marker light doesn't light up at all and it blinks very very dim in sequence with side marker light.  The two lights are supposed to alternate flash. Side marker only lights up turn signal, No parking light. Left side works as intended...
2002 Mustang GT Convertible (Mineral Grey)
2003 Mustang GT Convertible (Triple Black - wife D/D)
2013 Ford F550 XLT (Tow Truck - my D/D)
2006 Kawasaki Vulcan 750
1984 C10 Custom Deluxe
Re: Wiring issues
« Reply #1 on: October 04, 2017, 09:17:23 am »
Disassemble and burnish the cabin ground connections under the dash at the left kick panel/e-brake frame and between the engine compartment firewall and back of the right cylinder head.  Repair the open in the brown wire feeding the right front park and side marker lamps.  Disassemble and burnish the ground connections between the forward lamps and radiator support and between the radiator support and battery negative post.  As you reassemble the various ground connecting points, liberally coat the terminals and sheetmetal with antioxidant paste available in the electrical section of your local hardware store.  As a final step, if needed, replace the right front park lamp socket and 1157 dual filament bulb.
