73-87 Chevy & GMC Trucks
Choke
Topic: Choke (Read 15249 times)
Smitty31
1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
Choke
October 04, 2017, 08:59:45 am »
Ok 1986 4.3 v6, A.T. W/a 2wd. Should the choke plate be straight up and down when the engine is fully warmed up? Mine is not I would say it's 95% but not straight up and down.also the idle screw is not touching backed all the way off and the truck seems like it idles a little to high. The high idle adult mentioned foe cold starts seems to work. When the truck is cold it idles high after a few minutes I tap the gas and it idles down.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
bd
Re: Choke
October 04, 2017, 09:42:56 am »
The choke plate should be fully open at operating temperature. Make sure the electric choke thermostat is receiving 14 volts with the engine running.
With the engine
running
, spray for vacuum leaks using aerosol carburetor cleaner, concentrating your efforts around the base of the carburetor and along the intake manifold flanges. Check the radial play in the throttle shaft with the engine
not running
by grabbing the throttle lever, rotating the throttle open 10° - 15° and wiggling the shaft side-to-side while you watch the throttle shaft where it enters the carburetor baseplate. There should be ≤1/32" of side-to-side play in the shaft. If radial play is greater 1/32", the throttle shaft bore is worn, allowing the throttle plates to shift sideways in the their bores. Mis-registration of the throttle plates in their bores prevent the throttle plates from closing completely, allowing air to bypass the throttle, keeping the base idle high (implied by the base idle screw being backed completely out). The solution for excessive radial play is to bush the throttle bore and recenter the plates or replace the carburetor.
Edit: corrected auto-correction
Last Edit: October 04, 2017, 05:34:52 pm by bd
Smitty31
Re: Choke
October 04, 2017, 10:34:50 am »
I will check the volts today. Had the carb rebuilt all new gaskets and repaired all vacuum leaks. The worn throttle shaft could be I'll check. Could the high idle cam be out of adjustment. Causing it to idle high.
bd
Re: Choke
October 04, 2017, 12:18:51 pm »
Of course. If the choke doesn't open sufficiently for the cold idle screw to clear the lowest step of the fast idle cam, then a high idle can result. Force and hold the choke plate all the way open and cycle the throttle to see if idle RPM drops. If the cold idle cam is preventing throttle closing and the base idle speed screw is backed out as you've described, idle RPM should drop exceedingly low, possibly to the point of stalling the engine. That is, unless the throttle plates are shifting excessively in their bores as a result of throttle shaft bore wear in the baseplate.
Smitty31
Re: Choke
October 04, 2017, 02:54:28 pm »
Thanks for the info I will check tonight. Your not located in tennessee are you lol.
bd
Re: Choke
October 04, 2017, 03:39:07 pm »
I'm about 35 hours west of Tennessee.
Smitty31
Re: Choke
October 04, 2017, 04:59:48 pm »
I backed the high idle for cold starts off @nd it idled down way down to the point I had to adjust the other idle screw back up.
bd
Re: Choke
October 04, 2017, 05:31:47 pm »
That's great news! Correct the choke operation and you'll be good to go.
Smitty31
Re: Choke
October 04, 2017, 06:45:11 pm »
Here is a pic of the of the carb. You can see the choke plate is not straight up and down. The weird thing I can take my finger and move it all the way open and it will stay. I have replaced the choke thermostat and had the carb rebuilt.
bd
Re: Choke
October 04, 2017, 08:54:12 pm »
First, check the voltage at the choke stat as previously suggested. Is the choke stat riveted in place or retained by three screws?
The bimetal spring of the t-stat has a rectangular (box shaped) socket at its free end (RED ARROW) that engages a pin inside of the choke stat housing. The pin is integral with the linkage that operates the choke plate. The choke mechanism is designed for positive engagement and control of the choke plate. That is, the t-stat not only forces the choke plate closed when cold, but also forces the choke plate open as the engine warms. If the t-stat was inadvertently installed such that the linkage pin missed the spring socket, it might force the choke closed when cold, yet not pull it open as it heats, effectively causing gravity to open the choke instead of the thermostat.
OE electric choke stats generally are not adjustable, but instead designed to be indexed in a fixed position by a notch located on the periphery or outer circumference of the t-stat (BLUE ARROWS) and a corresponding tab on the mating inner circumference of the t-stat housing. There is more than one configuration that accomplishes the same task. If the choke stat was installed to miss the index, the t-stat simply might be rotated out of adjustment.
Smitty31
Re: Choke
October 05, 2017, 06:03:17 am »
It was fixed but the mechanic who built the carb fixed it with screws where it can be adjusted. I will check the volts and get back to you.
Smitty31
Re: Choke
October 13, 2017, 07:40:12 pm »
Sorry for the long delay I've been busy at work and in my spare time working on my truck. I checked the volts going to the carb it was indeed at least 14 volts. Choke is still only opening up about 95 percent its oh so close just not straight up and down. I will try to take a clearer pic tomorrow and post it.
bd
Re: Choke
October 17, 2017, 10:44:05 am »
Did you resolve this?
Smitty31
Re: Choke
October 18, 2017, 05:04:39 am »
Nope it still only opens up about 95 percent unless I take my finger and pull it straight up and down. It will stay then in less I push it back. Runs great warms up great also.
bd
Re: Choke
October 19, 2017, 03:24:07 pm »
Connect a DC voltmeter between the battery negative post and the choke t-stat housing then start the engine and measure the voltage. What is it?
Choke
