Author Topic: Brake drum backing plates, looking for.  (Read 6162 times)
Offline jntrndrm
« on: October 11, 2017, 07:33:35 am »
I'm looking for the rear backing plates for the 2-3/4" drum brakes , I haven't seen them any where. this is for an 80's 5 lug rear end.  Thanks for any help.  Don
Offline elijahcollins688
Re: Brake drum backing plates, looking for.
« Reply #1 on: May 03, 2018, 08:09:26 am »
These might work for you but I’m not sure. https://www.summitracing.com/parts/ado-15650129
« Reply #2 on: May 03, 2018, 08:10:12 am »
I also am having troubles finding backing plates for my 12 bolt truck and can only find them for a 12 bolt passenger.
Offline Fast68Chevy
  • I am THE Fast68Chevy!
« Reply #3 on: July 03, 2018, 04:29:56 am »
75 76 77 78 79 were the years most common for the BIG 10 and F44 big brakes 2 3/4"  were billions of them out there.  these are the plates you bolt onto the 69 and older housings to be able to convert them to 5 lug and use 5 lug shafts 71-up and make axle the same width as the later years ones.   this makes up the 1.5" width difference  3/4" plus 3/4"
1967/68 C30 dually truck build frame up currently.  1975 C20 YE9 pickup longfleet 96K original miles DD.  and tractors and more trucks.
Offline Ronno6
  • Elder Student
« Reply #4 on: July 06, 2018, 07:05:55 am »
The backing plates for the 11.15" x 2 3/4" (JB5) have 3 different part #'s for the years '74 to '87:
74 to 75 .....331447, 331448
76 to 82 .....357853, 357854
83 t0 91 .....14055278, 14055279
I believe they will all bolt up to 10 and 12 bolt housings, but am not sure what other differences exist.
They use the same shoes and drums.
I do not see the JB5 option for '73.
Now the disclaimer: This information is the result of my research from GM parts manuals, and is in no way guaranteed to be
valid beyond the information contained in those publications.
I urge you do do your own research before investing in any of the above parts for your particular application.
(I feel much better now....)
« Last Edit: July 06, 2018, 08:20:44 am by Ronno6 »
You can lead a man to water, but yoiu can't keep him from pissing in it.
Offline Ronno6
  • Elder Student
