Engine/Drivetrain
87 350 tbi 700r04 timing question
Topic: 87 350 tbi 700r04 timing question (Read 3714 times)
Jerr-conn
Retired tool maker
October 16, 2017, 05:55:40 pm »
I want to check the initial timing on my 87 350 tbi. I have read there is a tan/black stripe wire
Near th brake booster that needs to be unplugged before ck' ing timing. I have looked all over
Mine and have only found a tan/ white stripe wire that can be unplugged. Did GM change the
Color code for 87 or do I have to look harder? This wire is located in the area where a clutch
Pedal would be.
Jerry
bd
Re: 87 350 tbi 700r04 timing question
October 16, 2017, 06:41:28 pm »
Look again. The EST bypass connector on V8 applications breaks out of the engine compartment harness a few inches away from the firewall bulkhead connector just to the left of the brake vacuum booster. It is a single wire Weatherpack connector.
Smitty31
1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
October 17, 2017, 02:39:24 pm »
I know on some models it's under the carpet on the passenger side. Also if you have a vaccum advance you won't have this wire. Just simply unplug the hose and plug. Then set or check timing
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Jerr-conn
Retired tool maker
October 22, 2017, 03:47:23 pm »
Found the EST wire. Disconnected it re-set timing. Could not spin tires before, but it sure lights
Them up now. Timing was so retarded. Set it at 2 degrees BTDC. Happy now , except it's almost
Time to put it away for the winter.
Jerry
Engine/Drivetrain
