Author Topic: tranny help please  (Read 7158 times)
Offline 82chevysw
tranny help please
« on: January 17, 2006, 12:13:00 am »
k guys i have an 82 chevy swb with a 350 oldsmobile motor in it, the tranny went bad, and i happen to have a 350 turbo tranny just settin around.. is there anyway i can use this tranny on this motor? ive been told no but i wanna know from u guys.. thanks in advance
Offline Ziptar
Re: tranny help please
« Reply #1 on: January 17, 2006, 04:42:00 am »
Yes you can use it. You need a BOP (Buick, Olds, Pontiac) Adapter. Summit Racing sells TCI's adapter for $54.00 + Shipping.
« Reply #2 on: January 17, 2006, 05:59:00 am »
What did the TH350 come out of? If came from Buick, Olds, or Pont. it will bolt up as is. What is in the truck now, auto or std.? If auto is it TH350 long or short shaft? Is it a TH400?Needs more info to give a detailed answer.
Offline 82chevysw
« Reply #3 on: January 17, 2006, 07:02:00 pm »
ok thanks for the info ive gotten now ill give u more, its a chevy truck, with an oldsmobile motor and tranny, not sure what kinda tranny the truck had that is slippin, but it is long shaft.. tthe back of the olds motor like curves down, and so does the tranny that was in it, but the turbo tho i got down curve down at the top, it curves up, so i was told it wont bolt right upp.. and the 350 turbo i have is a long shaft too. both look almost the same just one dips down wherew it bolts to the motor and one curves upwardd. just trying to figure out if i can use the turbo 350 or if ill have to buy a new tranny that dips downward.
Offline 1976Scottsdale
« Reply #4 on: January 17, 2006, 09:57:00 pm »
Should just need the 54 dollar adaptor they were telling you about.  Thet is the difference in the engines is the mounting pattern.  Just get the adaptor and you will be squared away, might also consider some flexplate shims to keep everything in line, but you may not need to.
