Author Topic: AAW Power Plus 20 in 1984 C30 Crew Cab Camper Special  (Read 6611 times)
Offline TonimusMaximus
  • That guy
« on: October 22, 2017, 12:55:03 am »
I'm nearing completion on re-wiring my 1984 C30 Crew Cab Camper Special.
So far, the only components from the original electrical system that have been reused are: Power window/lock harness and switches, ignition switch, turn signal switch, and the hazard switch.
I accidentally pulled the guts out of the door lock relay and I wan't going to buy a $100 NOS one on eBay, out of principle. I wired two 30 amp 5 pin relays to replace the original lock relay and it works great. I'll try to remember to post pictures of that setup.
The AAW Power Plus 20 uses an OEM ATO style fuse block. This was great, because I was able to use the cab side of the original bulkhead connector to plug up the hole on the firewall and it allowed me to use the original bolts to secure the fuse block in the original position.
A few departures from a direct replacement using all the original switches... Instead of wiring the column mounted high beam switch, I used the floor mounted switch the kit came with. I prefer the floor style anyway. Also, instead of figuring out the delay wiper bulls***, I'm wiring the wipers with a toggle that should retain the park feature of the wiper motor. If someone was so inclined, it wouldn't be difficult to use an earlier model slider switch for the wipers. Since this truck is going to have several toggles for various features in the future, that's what I decided on.
Engine compartment wiring was simple and had ample wiring for everything.
Front lighting, same.
Rear lighting, simple, but not enough wire for a crew cab long bed. Plan on at least 12 extra feet being needed for the rear lighting, in green, yellow, and brown.
I'm still working on the cabin wiring, that is coming tomorrow. As of right now, it moves under its own power and all the exterior lighting works (except brake lights due to me buying the wrong switch).
Below are some obligatory pictures.
As it was.
Both fenders were badly cracked. The fenders were cut off and outer wheels removed to get it to fit in the shop.
Wiring gutted.
I was tired of the sharp edges. Remnants removed. If the driver fender looks funny, that is because I used the fiberglass support rod and bolted it to the front edge of the wheel well to keep it from flapping in the wind. Ended up doing the same on the other side.
Working. Pulled the front carpet out because a previous owner must've had a mechanical oil pressure gauge spring a leak on the drivers side. Carpet and padding were soaked with old oil.
Running wire is so much easier when your best friend has a shop in his back yard with a lift...
Yay! Working lights!
« Last Edit: October 22, 2017, 01:03:31 am by TonimusMaximus »
'78 C10 Burb
  • That guy
Re: AAW Power Plus 20 in 1984 C30 Crew Cab Camper Special
« Reply #1 on: October 22, 2017, 01:01:33 am »
I forgot to add that I will not be integrating AC/heat. I am planning on doing a Vintage Air system at a later date. Also, I removed the whole dash because the thing was shot. Arizona sun.
'78 C10 Burb
  • That guy
« Reply #2 on: October 22, 2017, 10:15:56 pm »
This is how I wired my replacement for the original power lock relay.
Relay A pinout-> GM plug
87 -> 60
87a & 85 -> New ground wire
86 -> 195
30 -> 294
Relay B pinout-> GM plug
87 -> 60
86 -> 194
30 -> 295
OE cab side bulkhead connector with hole drilled in the middle for wire pass-through.
Much simpler engine wiring. Cleanup will come later.
'78 C10 Burb
  • That guy
« Reply #3 on: October 24, 2017, 01:42:04 am »
Well, I'm done for now. Everything works as it should. Radio, dome light, door switches, and A/C (way out) will have to wait until I get back from a rocket launch in a couple weeks.
I had no issues integrating the Power Plus 20 kit with the truck. GM color code and fuse block were nice. I wouldn't hesitate to recommend this kit to someone looking for a budget kit to redo their truck or car.
"Finished" fuse block.
'78 C10 Burb
« Reply #4 on: October 25, 2017, 09:27:07 pm »
must say i love the idea about the ceiling being too low for the lift.
keep us updated on the project
  • That guy
« Reply #5 on: October 26, 2017, 05:23:50 pm »
Hah. It's only too low for a truck. The cars we work on go up into the recess in the ceiling perfectly. I can stand underneath them, and I'm 6'5".
'78 C10 Burb
« Reply #6 on: October 26, 2017, 08:05:02 pm »
is that a 10 foot ceiling?
  • That guy
« Reply #7 on: October 26, 2017, 11:35:43 pm »
Yeah, 10' with a little more than an extra foot of recess above the lift.
'78 C10 Burb
« Reply #8 on: October 27, 2017, 05:53:05 pm »
by the looks of it we have about the same set up. i just moved in to my house and i can get my truck to fit but my moms E150 Econoline wont. i want to eventually put a lift in and get the door a couple feet taller just to fit other vehicles. i just dont know how easy/cheap it will be
  • That guy
« Reply #9 on: October 27, 2017, 06:49:34 pm »
The truck will go about 10-12 inches higher than it is in the pic, but the height it is at is perfect for rolling around on a shop stool underneath it. The lift is a Rotary Revolution RTP9, 9000 pound capacity with proper anchoring. About $3k for the lift, plus freight and install. Minimum ceiling height is 9'5" for that lift.
'78 C10 Burb
