Author Topic: 700r4 swap  (Read 9113 times)
Offline daman02
700r4 swap
« on: January 01, 2006, 08:37:00 pm »
i have a 86 silverado with a factory turbo 400 in it.  I'm about to convert to a 700r4.  Will it drop right in w/o any driveshaft mods?  what all do i need to complete the installation?
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Offline roundedline
Re: 700r4 swap
« Reply #1 on: January 02, 2006, 02:04:00 pm »
The trans mount will have to moved, and the input shaft will have to be changed.  I can't remember exactly, but I think the driveshaft lenght might have to be modified also
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Chevynut
Re
« Reply #2 on: January 19, 2006, 06:08:00 am »
I've thought about instaling a 700r4 in my '73 350/350.  The question is - will it go in and hook up ok?  Sure would like to have that 4th gear :D .  Hope yours works out ok.
Thanks
'73 Cheyenne
Long live the Chevy Truck
Offline daman02
Re: 700r4 swap
« Reply #3 on: January 19, 2006, 08:08:00 am »
if you have a long tailshaft 350 the 700r4 should bolt right up w/o any driveshaft mods.
Offline Ziptar
Re: 700r4 swap
« Reply #4 on: January 20, 2006, 04:04:00 am »
I can confirm that, swapped my Long Tail TH350 for a 700R4, everything fit right into place with the exception of having to drill 5 new holes in the fram to accomodate sliding the trans cross memebr back about 1.5".
Offline Chevynut
Re
« Reply #5 on: January 20, 2006, 05:00:00 am »
Sounds good - and thanks for the info.
'73 Cheyenne
Long Live The Chevy Truck
