Author Topic: Air filter  (Read 2722 times)
Offline Hulkjoegan
Air filter
« on: October 26, 2017, 09:02:27 pm »
1985 454 w/quadrajet
It still has the stock air cleaner, inside of the replaceable air filter is a metal screen air filter. I'm assuming that is a washable filter, correct?
If I ditch the stock cleaner and go with an open element filter, will there be much adjustment to the carb? Or is it really plug n play?
1985 Suburban C20 Scottsdale "Bonnie the 'burb"
454 Quadrajet TH400
Re: Air filter
« Reply #1 on: October 27, 2017, 08:30:24 am »
The metal screen is a flame arrestor to protect the filter element from backfire.  Eliminating the factory air cleaner will also eliminate TAC, which may introduce cold driveability problems.  TAC warms the air entering a cold engine to aid fuel vaporization.
