Author Topic: Locking Hubs  (Read 6627 times)
Offline scott75k20
Locking Hubs
« on: October 29, 2017, 10:58:29 pm »
I have a 1982 GM 10 bolt 4x4 front axle that I pulled out the driveshafts and replaced the wheel bearings and seals, when I put it back together the locking hubs will not slide in enough that I can get the retaining clip on it. I can't figure out where the problem is. Any ideas?
Offline jetman
    • Squarebody Referance Library
Re: Locking Hubs
« Reply #1 on: October 30, 2017, 09:09:29 am »
Not sure if you have auto or manual hubs, or exactly what the problem may be.  But I do know of that clip, I always put a slight bend into one end to make it easier the next time I need to take it out.  There is full tech info (factory drawings and shop manual R&R) at http://www.bacliffrv.com/Truck .
Offline scott75k20
Re: Locking Hubs
« Reply #2 on: October 30, 2017, 08:08:49 pm »
It has manual locking hubs. Its like both spindles need to be moved inward or both axle shafts need to extend outward and 1/8 to 1/4 inch to expose the grove in the end of the axle shaft that the snap ring fits into.
Offline Captain Swampy
  • Wisconsin
Re: Locking Hubs
« Reply #3 on: October 30, 2017, 11:41:12 pm »
Push the axle shaft out  with a screw driver or pry bar.  You get at it by the ball joints.
