Author Topic: shift linkage  (Read 6194 times)
Offline daman02
shift linkage
« on: January 26, 2006, 11:43:00 pm »
i just switched from a 400 to a 700r4 tranny and have everything in but when i went to bolt up the linkage the transmission will only shift from 1st, 2nd, and drive after that it is stuck.  i think the rod is gettin in a bind from being back farther in the 400.  anyone know if i will need a new shift rod or not or how i can fix this?
'86 C10 Silverado 350 with 700r4 and 2500 stall
Dropped 2" in front and 2" in rear but soon to b 4" in rear
18x10 wheels with 295/45 18 tires
Re: shift linkage
« Reply #1 on: January 27, 2006, 06:14:00 am »
Not sure, just didn't want you to think noone was answering you.
Offline roundedline
Re: shift linkage
« Reply #2 on: January 27, 2006, 12:32:00 pm »
Are you saying you put it in D and is doesn't shift out.  Or physically the gears in the tranny won't shift to all gears?  Does it shift if the rods are disconnected?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline daman02
Re: shift linkage
« Reply #3 on: January 27, 2006, 07:52:00 pm »
the rod that comes down from the linkage in the firewall seems to be bent at a different angle for the 400 and when i hook it up to the transmission it will not go up past drive.
