Author Topic: Gasoline motor sounds like diesel?  (Read 8774 times)
Offline PStansb
« on: January 20, 2006, 11:34:00 pm »
OK - I'm not sure the best way to describe this, but my 305 V8 gasoline motor often times sounds like a diesel engine when I accelerate.
Any ideas what would cause this, or even what it may be?  Again, I'm sorry for the not-so-technical description, but that's what it sounds like.
This is an 81' C-10 with 305 V8, 4BBL.
Thanks,
Paul Stansberry
Offline ChevyGuy
diesel
« Reply #1 on: January 21, 2006, 12:21:00 am »
Exhaust leaks?
Offline toplessblazer
Re: diesel
« Reply #2 on: January 21, 2006, 12:55:00 am »
Spark knock. You may need to time your engine and try running higher octane gas
Offline PStansb
Re: diesel
« Reply #3 on: January 21, 2006, 07:48:00 am »
I've owned an 80' before that did the same thing and it WAS as simple as running higher octane.  However, I am already running 91 octane in this one and it hasn't resolved the problem.
I'm about to replace the spark plugs and wires...  do you think that would help?
ChevyGuy - When you say exhaust leaks...  what do you mean?  How would that cause the motor to run this way?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Diesel
« Reply #4 on: January 22, 2006, 12:11:00 am »
Retard your timing a tad.  That is the sound of your valves clattering when you accelerate.
SgtDel
Offline ChevyGuy
knock
« Reply #5 on: January 22, 2006, 08:16:00 am »
The knock is also part of it running bad? I had exhaust leaks before that made it sound that way thats why I said that.
Offline 1976Scottsdale
Re: Gasoline motor sounds like diesel?
« Reply #6 on: February 18, 2006, 06:21:00 am »
This one is a definate long shot, but mine did it twice before I got the message that it was broken.  Make sure that your distributor itself in all the way in.  Mine was hanging out about 3/4 of an inch.  It ran, it just hammered really hard.
