Author Topic: Brake ID questions  (Read 4069 times)
Offline Halogin13
Brake ID questions
« on: December 11, 2017, 07:53:48 pm »
Hi All.. Need some help ...
1987 V10 Silverado, 5.7L TBI....
I have a 14 bolt rear end, and 8x6.5 bolt pattern......
1)was this a setup that was available originally? Or has there been an axle swap?
2)Theoretically, I should have a JB5 setup, right?
I want to replace my brake shoes, but without opening the whole thing up and taking out the axle etc., is there a way to confirm shoe size from the attached pics?
1987 V10 P/U
Re: Brake ID questions
« Reply #1 on: December 11, 2017, 09:14:40 pm »
That axle was swapped in.  The brake drum should be stamped with the diameter.  I would be willing to bet if you go and ask for rear brakes for a 1978 C20, you should get the right ones.  After 81 GM 8 lug axles were the semi float unless you had a 8600GVW
Offline Halogin13
« Reply #2 on: December 12, 2017, 09:14:05 am »
Thank you !
1987 V10 P/U
