Author Topic: Where should this Tan/White Wire Connect?  (Read 3840 times)
Offline SJSbackyard
« on: December 18, 2017, 08:28:42 am »
Recently purchased 1987 3500 High Sierra, 350cid, w/TBI. Just forward of the TBI, there's a tan/white wire that is not connected. I'm hoping someone can identify where, in the fuel related system, it should be connected. I have attempted to attach a photo showing the wire (colored arrow).
The issue I'm working on is to solve a cold start problem...
« Last Edit: December 18, 2017, 08:36:36 am by SJSbackyard »
Offline Captain Swampy
  • Wisconsin
Re: Where should this Tan/White Wire Connect?
« Reply #1 on: December 20, 2017, 09:37:02 am »
If no one answers I'll try to look tonight or tomorrow.
1987  350TBI 700R4  4X4  4.56 gears  33" BFG All Terrain
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32209.0
Offline SJSbackyard
« Reply #2 on: December 20, 2017, 01:11:32 pm »
Thank-you.
I tested and found continuity between the tan/white wire forward of the TBI, and the fuel pump relay (firewall). They're certainly within the same circuit. I next checked for voltage...none...appears as a ground. I really don't like to have a stray wire left, as I'm currently installing two fuel tanks and pumps.
Online bd
« Reply #3 on: December 20, 2017, 02:13:46 pm »
Circuit 551, Tan/Wht:  ECM ground connected to intake manifold stud adjacent to thermostat housing.  See the 1987 Wiring Manual, grid Q43.
Offline SJSbackyard
« Reply #4 on: December 21, 2017, 05:21:26 am »
Thank you "bd"
Another loose-end taken care of...  ;)
