Author Topic: '87 GMC R3500 Access Cover w/i Cab?  (Read 4176 times)
Offline SJSbackyard
« on: December 22, 2017, 09:47:02 am »
Before attempting to remove rubber cab flooring in these freezing temps...
Does the cab of my '87 GMC R3500 High Sierra (dump) truck have a removable access cover for the reverse switch? 4-speed manual transmission.
Re: '87 GMC R3500 Access Cover w/i Cab?
« Reply #1 on: December 22, 2017, 10:17:44 am »
No they stopped using removable covers in 1984 I believe
Offline SJSbackyard
« Reply #2 on: December 22, 2017, 10:25:25 am »
zieg85, thank-you. I believe I felt the switch on the left side/upper of the transmission. Plug is off, yet I was hoping access would be provided elsewhere...hoping certainly doesn't make it so...  ;)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: December 22, 2017, 03:40:13 pm »
Space is extremely limited, however, I believe you can just reach the plug through the shift boot, I think this was how I reached mine I initially.
Otherwise from the bottom is the only way. And it is kinda tight.
 1986 Chevy K30(under repair)
