Author Topic: project onion rings  (Read 299905 times)
Offline chevn-up
Re: project onion rings
« Reply #180 on: July 14, 2023, 07:33:37 pm »
I removed the spring from the used hose, happy to see routine maintenance has kept it clean and rust free. Ran a pull-wire through the new hose, squirted a little soapy water, and with my lovely wife pulling, and me pushing, installed it into the new hose. Easy cheesy. This falls under the "better safe than sorry" category. Hope this helps others.
Offline Chevynut73
« Reply #181 on: July 16, 2023, 04:07:56 pm »
Nice project - looking great!
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Offline chevn-up
« Reply #182 on: August 06, 2023, 06:52:35 pm »
The fluids. Been awhile since the truck was street worthy. Confidence is high.
Offline Shifty
  • I bleed Bowtie red...
« Reply #183 on: August 07, 2023, 02:40:11 pm »
Waiting with baited-breath....I know, I know, stand closer to the toothbrush.... ;)
98 C2500 ext cab longbed
Offline chevn-up
« Reply #184 on: July 20, 2026, 05:57:25 pm »
Soooo long not being here. 3 years, Yikes! In all that time I still kept the faith to get to the end of the tunnel. Its ok to give up, just never surrender. I may have been beaten up, but I still aint beat.   On with the show! After 12 years the truck has finally seen the sun.
« Last Edit: July 20, 2026, 06:19:58 pm by chevn-up »
Offline chevn-up
« Reply #185 on: July 20, 2026, 05:59:24 pm »
again
Offline chevn-up
« Reply #186 on: July 20, 2026, 06:03:18 pm »
I think I left off with the improved grille
Offline chevn-up
« Reply #187 on: July 20, 2026, 06:06:56 pm »
Problem with too much negative camber, so invested in different A-arms.
Offline chevn-up
« Reply #188 on: July 20, 2026, 06:28:33 pm »
used a straight piece of metal with a 1 inch angle to get the wheels "close"
Offline chevn-up
« Reply #189 on: July 20, 2026, 06:31:29 pm »
these are the extra unused shims from the last alignment, at best.
Offline chevn-up
« Reply #190 on: July 20, 2026, 06:36:37 pm »
While I had the front wheels off, I dressed things up a bit.
Offline chevn-up
« Reply #191 on: July 20, 2026, 06:39:16 pm »
Added traction bars also. These things are cool
Offline chevn-up
« Reply #192 on: July 20, 2026, 06:43:43 pm »
On my install, I needed to cut the lower leaf in the spring to clear the connecting bar on the traction bars. First cut and they still hit with the suspension fully hanging. So a second cut was necessary. Good now
Offline chevn-up
« Reply #193 on: July 20, 2026, 06:46:00 pm »
While back there, I cleaned up the shocks also.
Offline chevn-up
« Reply #194 on: July 20, 2026, 06:46:36 pm »
sexy
