Author Topic: 283 cam bearings  (Read 7722 times)
Offline 123 pugsy
283 cam bearings
« on: February 24, 2006, 05:13:00 pm »
I got my block back this week with new cam bearings installed.The rear has the hole at the bottom but does not seem to line up with a hole in the block.The front one has 2 holes and only the bottom hole lines up.Is this correct?????
Pugsy
76 C10 LWB
TPI 350
Offline usmcchevy
Re: 283 cam bearings
« Reply #1 on: February 25, 2006, 08:12:00 am »
i believe all the holes in the bearings should line up with the holes in the block. how else can the cam get lubricated?
Offline 123 pugsy
« Reply #2 on: February 25, 2006, 09:25:00 am »
After some surfing ,I've learned there is a groove in the block for the oil to flow through and come out the hole.Some say it can be anywhere,some say all the holes must be lined up,some say the hole only needs to be over the groove...>:
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #3 on: February 26, 2006, 09:23:00 pm »
Well I put the engine together this weekend.Should be ready to install by next weekend.Hopefully the oil hole being over the groove will be OK.
Edited by: 123 pugsy at: 2/26/06 9:25 pm
Pugsy
76 C10 LWB
TPI 350
