Author Topic: Bed Mat  (Read 8782 times)
Offline Combat Veteran
  • Square
Bed Mat
« on: January 10, 2018, 09:07:57 pm »
Has anyone found a rubber bed mat that will cover the entire bed? Searching high and low and can't believe no one sells anything for our trucks.
1987  slightly modified Custom Deluxe V10, 350TBI, 700R4,  NP208, 4X4,  4.42 gears,  33" Firestone Destination M/T
Re: Bed Mat
« Reply #1 on: January 10, 2018, 09:14:25 pm »
They haven't been available for a while due to our trucks age.  Not a lot of call for them anymore.  Luckily they have some decent DYI bed liner coatings.  Every once in a while I see them at the junk yard in a truck
Offline Monkey Uncle
Re: Bed Mat
« Reply #2 on: January 11, 2018, 05:52:58 am »
Yeah, I looked high and low a few months ago and came up dry.  Pendaliner still makes an under-rail bed liner that will fit - that's what I ended up going with.  I found a local shop that was willing to order it for me for a little less than I could get it for the on-line price plus shipping.
  • Square
Re: Bed Mat
« Reply #3 on: January 11, 2018, 09:09:30 am »
Closest thing I found to what I was looking for. Westin 50-6325 Truck Bed Mat, $105 on Amazon.
Cut to fit.
https://www.amazon.com/gp/product/B00F6XA3PS/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Offline Jason S
Re: Bed Mat
« Reply #4 on: January 11, 2018, 09:29:08 am »
Had same issue trying to find a bed mat for my 64 F-100.  Bought rubber sheet that had diamond plate pattern and I cut-to-fit.
At the time the rubber sheet came as bulk material on a roll, about 1/2" thick and around 6-feet wide and had it cut at 8' long. Found it at a trailer supply shop in Fort Worth, TX.
The link below is to their catalog page with a similar mat.  They list a 5x10 and 6x10 sheet that might work for you.
http://www.capleshaw.com/catalog/118.html
The sheet can be trimmed to fit fairly easy.  I wound up using a utility knife and large tin-snips (shears).  The mat has held up well for going on 20 years.
You might be able to find something similar at a trailer supply local to you.
Offline smurfasaur
Re: Bed Mat
« Reply #5 on: January 11, 2018, 02:49:33 pm »
  Truck has them
http://www. competitor.com/icatalog/cc/full.aspx?Page=147
Offline smurfasaur
Re: Bed Mat
« Reply #6 on: January 11, 2018, 02:55:40 pm »
Dang I guess they really don't want people talking about other old truck part companies on here? Here's the link in jpg format since the online store here doesn't have them I don't think it should be a problem to give this info.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Bed Mat
« Reply #7 on: January 11, 2018, 04:57:51 pm »
It is a problem for a couple reasons, and I believe is part of the agreement when signing up on this forum. Well mainly the one you are talking about, there are a couple others that don't get blanked out.
 1986 Chevy K30(under repair)
