Author Topic: computer/check engine light  (Read 3197 times)
Offline NCali
« on: January 28, 2018, 02:20:31 pm »
when you turn the ignition switch to the on position the check engine light should flash twice I think.
   Mine sometimes does not come on at all. when that happens , I pull the ecm fuses out and the crank fuse. I put the same fuses back in and it will work.
  I get no codes when checking for them
any Ideas?
Black Labs Matter
