Author Topic: Cooling  (Read 4053 times)
Offline tonyb
Cooling
« on: January 29, 2018, 02:59:24 pm »
Cant find a spot for this item, the 78 was parked outside last night, -10, couple of antifreeze spots on ground dripping from front shackle mounts, don't seem to be any hoses leaking. I had installed a new radiator, aluminum core with plastic side tanks. Could the cold be shrining the aluminum enough to lead at the seams? Did not leak in the heated shop for a week prior. thoughts?
Offline MrFiveOh
  • The Local Po-Po
Re: Cooling
« Reply #1 on: January 29, 2018, 03:56:13 pm »
what side and throw some pics up if you van.
1974 C-10 AKA "Smurf"
Offline tonyb
Re: Cooling
« Reply #2 on: January 29, 2018, 04:20:17 pm »
Both sides, the tray/cradle it sits in is wet.
Re: Cooling
« Reply #3 on: January 29, 2018, 05:31:38 pm »
As long as you have coolant in it, recheck the hose clamps.
Offline tonyb
Re: Cooling
« Reply #4 on: January 29, 2018, 10:30:05 pm »
k, thx
Offline Stewart G Griffin
Re: Cooling
« Reply #5 on: January 31, 2018, 08:05:46 am »
Don't forget the water pump.
