Author Topic: 87 350 tbi a/c drive belt  (Read 4619 times)
Offline Jerr-conn
  • Retired tool maker
« on: February 08, 2018, 09:01:06 pm »
Last spring I put a new a/c belt on . It slips and squeals like heck when I turn
Air on. Belt is tight. Might be too narrow. Not sure, but might be 3/8".                                      Want to know what is the best belt To buy and dimensions including width? Or pt # ?
Jerry
Re: 87 350 tbi a/c drive belt
« Reply #1 on: February 08, 2018, 10:31:37 pm »
W/P, crank, P/S pump, A/C compressor:  7/16" x 55.5"  Goodyear Gatorback 15561
Crank, P/S pump:  7/16" x 39.5"  Goodyear Gatorback 15402
Offline haroldwca
« Reply #2 on: February 09, 2018, 10:30:21 pm »
Is your AC compressor in good working order?  When the AC is switched off, the belt idles on the compressor pulley.  When the switch is turned on, the compressor clutch engages the compressor pulley to the compressor internals.  If the compressor is seizing, when you switch the AC on, the belt will be pulled around a pulley that cannot rotate.  This will not last long, as it will burn the belt off. I would begin by checking the compressor.
Offline Jerr-conn
« Reply #3 on: February 10, 2018, 11:14:38 am »
The clutch works good . A/c comp is good. Used some special belt dressing and squealing stopped for a week. Am sure I have too narrow belt. Will try belts as suggested by B D. Thanks anyway.
Jerry
Offline Jerr-conn
« Reply #4 on: February 10, 2018, 12:20:06 pm »
B D /Rich-----having a heck of a time finding someplace that carries Goodyear gator back belts.
Amazon listed some but not those pt 15561 & 15402. Any ideas?   Thanks.    Jerry
Jerry
« Reply #5 on: February 10, 2018, 01:45:55 pm »
Just cross the numbers to Dayco or Gates.
Offline Jerr-conn
« Reply #6 on: February 10, 2018, 04:41:15 pm »
Thanks again Rich.
Jerry
