Author Topic: Wiring a Tach on a TH400  (Read 6124 times)
Offline RGSMS
« on: February 17, 2018, 01:33:00 pm »
Just got a new gauge cluster and it has a tach on. It (my old one never had one). I was wondering how to wire it from trans to gauge.
Offline Rapid Roy
  • Euless, Texas
Re: Wiring a Tach on a TH400
« Reply #1 on: February 17, 2018, 01:56:33 pm »
Welcome to the site
Mopar by Birth
Chevy by Choice
« Reply #2 on: February 17, 2018, 02:06:05 pm »
A tachometer (tach) registers engine RPM so has no connection to the transmission.  Pink to 12-volt ignition, black to ground, brown to the negative terminal of the coil (the TACH terminal of the distributor if HEI).
Offline RGSMS
« Reply #3 on: February 17, 2018, 09:08:24 pm »
Ok awesome thanks guys
Offline 75gmck25
« Reply #4 on: February 18, 2018, 07:38:38 pm »
Most auto parts stores sell the correct terminal that plugs directly into the tach connections on an HEI.  You need a connector similar to this one.  https://www.amazon.com/American-Autowire-500205-Distributor-Tachometer/dp/B003VXLOSU
You can make a female spade terminal work if you have to, but it is only kept in by the friction of the metal tab.
Bruce
