Author Topic: Battery drain  (Read 5301 times)
Offline jwpa2
Battery drain
« on: February 25, 2018, 04:30:45 pm »
I got this truck (supposed) to be (quick fix) and drive, ha ha ha, so after we completely rebuilt front end, all u joints, steering column, dash cluster parts, dash pad, rear wheel cylinders, still needs the right radiator, tires, and seat, now the battery was running down wondered why on heater selector you turn the fan on with key off the fan runs, unplug fan and all those components on a/c box under the hood and the battery will stay charged, does anyone know what I need to change so I can leave it plugged in so I can run heat. (My wife nick named it POS), thanks for any help and info.
Online Rapid Roy
  • Euless, Texas
Re: Battery drain
« Reply #1 on: February 25, 2018, 07:01:58 pm »
Welcome to the site
Mopar by Birth
Chevy by Choice
Re: Battery drain
« Reply #2 on: March 05, 2018, 01:02:07 pm »
Please include Year, Make, Model etc.. when posting
Begin by discovering from where the blower is drawing power.  Chances are high that someone improperly connected the power wire that feeds the heater control head and fan switch to Battery instead of Accessory at the fuse box.
Offline jwpa2
Re: Battery drain
« Reply #3 on: October 21, 2021, 11:12:15 am »
O sorry it's a 84 on 86 frame GMC 4x4, what I found was that a steering column I put in must of been something different about it because I fixed another one for that year and no longer had that problem.
Offline JohnnyPopper
  • Old Goof
Re: Battery drain
« Reply #4 on: October 21, 2021, 07:56:46 pm »
You wife is named Nick?
What till you're burning rubber, or just stylin on the weekend, she'll name it something else. Or change the meaning of the acronym to save face...
1980 C-10 under construction
