Author Topic: New power steering pump without separate reservoir  (Read 3905 times)
Offline robosmurf
« on: February 27, 2018, 10:01:07 am »
87 454 with TBI. It has a power steering pump with the aspirate separate reservoir mounted near the thermostat housing.
Is there a swap for a pump with the reservoir on the pump?
I'm trying to clean up the engine compartment.
Sent from my SM-G920V using Tapatalk
84 c20 Camper Special
454ci with TBI
Offline jetmech
Re: New power steering pump without separate reservoir
« Reply #1 on: March 02, 2018, 12:00:56 am »
I'm sure you could modify the pump or replace it with a small block pump but never tried it. I also have an '87 one ton. At least it is easy to fill.
I am keeping my eyes open for a 90's factory serpentine setup for my 454 in a '86 C10 build which has a reservoir as part of the pump and would
 give me a more common and less expensive AC compressor.
'86 Sub and '86 SWB C-10
1990 454 SS
