Author Topic: power steering gear input shaft seal  (Read 3459 times)
Offline jstatic77
« on: March 02, 2018, 10:40:33 am »
My 80 C30 has input shaft seal leaking a little. Not the pitman seal. the ruck i recently purchased and has been sitting a while
My question is...... has anyone replaced the seal with gear box in the vehicle?
I would rather not remove the lines and make a big mess, I understand I have to unbolt to get rag joint separated which is fine then I can bolt back up and work on seal.
