Author Topic: 86 C10  (Read 7906 times)
Offline Marty McFly
86 C10
« on: March 13, 2018, 09:58:12 pm »
New to this forum and new to restoring but I’m just trying to get some tips and honestly trying to get advice on where to start, thanks in advance gents.
Offline Jason S
Re: 86 C10
« Reply #1 on: March 13, 2018, 10:11:52 pm »
Welcome from Kansas
Offline Marty McFly
Re: 86 C10
« Reply #2 on: March 14, 2018, 12:05:50 am »
To add more info on my truck it runs decently and can be used to take me from point A to B but I don’t fully trust it on highways due to its low performance which is what I’m trying to work on I care more for performance than looks, thanks again
-rookie
Offline Marty McFly
Re: 86 C10
« Reply #3 on: March 14, 2018, 12:06:44 am »
Welcome from Kansas
Thanks from Texas
Offline Rapid Roy
  • Euless, Texas
Re: 86 C10
« Reply #4 on: March 14, 2018, 06:13:34 am »
Welcome
Mopar by Birth
Chevy by Choice
Online zieg85
Re: 86 C10
« Reply #5 on: March 14, 2018, 07:44:17 am »
Welcome from the St. Louis, MO area!
Re: 86 C10
« Reply #6 on: March 15, 2018, 06:22:49 pm »
welcome from maryland
take a look here, for some areas/post to check out. first thing to check out is the safety (i.e. brakes, tires, brake fluid, coolant, oil and trans fluid) then do a tune up (plugs, wires if needed, fuel filter, air filer and trans fluid and oil changes) then learn how to tune up your carb and set your timing. most of that stuff can be found in the link i posted.
« Last Edit: March 15, 2018, 06:37:49 pm by Irish_Alley »
Offline Marty McFly
Re: 86 C10
« Reply #7 on: March 15, 2018, 06:27:05 pm »
take a look here, for some areas/post to check out. first thing to check out is the safety (i.e. brakes, tires, brake fluid, coolant oil and trans fluid) then do a tune up (plugs, wires if needed, fuel filter, air filer and trans fluid and oil changes) then learn how to tune up your carb and set your timing. most of that stuff can be found in the link i posted.
Thanks brother!
Offline Ol Blue
Re: 86 C10
« Reply #8 on: March 15, 2018, 08:54:27 pm »
Hello from Florida!
