Author Topic: WOOD DIMENSIONS FOR SB/SS  (Read 5933 times)
Offline echo7bravo
« on: March 17, 2018, 03:45:46 am »
I am looking to cut/mill my own boards for my build. However, I cannot seem to find the specifications for the wood anywhere. It seems everyone has the dimensions for the boards and bolt holes for everything up to 1972. But I am having the hardest time finding the information for 73-87.
Any help would be greatly appreciated.
Online Rapid Roy
  • Euless, Texas
Re: WOOD DIMENSIONS FOR SB/SS
« Reply #1 on: March 17, 2018, 09:22:06 am »
Welcome
Mopar by Birth
Chevy by Choice
« Reply #2 on: March 17, 2018, 04:16:03 pm »
echo i cant help you with the numbers now. but i know some have talked about the size on here. im sure someone else will chime in with the answer or you might be able to find it with the "search" button
Offline echo7bravo
« Reply #4 on: March 18, 2018, 11:28:42 pm »
I emailed GMC Pauls and was told that they believe the the square body bed boards are the same dimensions as the 67-72 models.  I'm still not sure about the bolt hole placement.  I may end up using some scrap lumber to mark the bolt holes from the bottom and using as a makeshift template for my bed boards.
« Reply #5 on: March 19, 2018, 01:09:59 pm »
if you do find your answer, would you post them on here so we can have them for future use. if you do a write up with pictures that would be even better. that way we can make it a sticky and throw it in the tech section
