Author Topic: 4speed to 5 speed transmission swap  (Read 6216 times)
Offline 427adam
« on: March 27, 2006, 01:16:00 am »
I am the new owner of a 1985 crew cab dually. (454 and M465 4-speed) I would like to either replace the old 4 speed with a newer style 5 speed or add a Gear Vendors auxilary transmission. Does anyone have any experience or suggestions? There is a few companies that sell "conversion kits" for changing the whole transmission. Is the Tremec TK0-II or the New Venture NV 4500 the stronger transmission? I know the old Muncie is nearly bulletproof and adding an auxilary transmission would be the easiest, and probably most expensive route. I was thinking that the newer transmission may shift a little nicer??? Comments??? Thanks -Adam
Offline roundedline
Re: 4speed to 5 speed transmission swap
« Reply #1 on: March 27, 2006, 02:21:00 pm »
If you are using the Truck for "work", the TKO is a passenger car trans, so you want to get the NV4500.  It is like the SM465 with an overdrive.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
