Author Topic: Can i use a 3 speed automatic column for a 700r4  (Read 8172 times)
Offline burnze
« on: April 01, 2018, 09:17:51 pm »
1987 r10 355/700r4/4.11 it has a non tilt column I found a tilt column it came out of a truck with 350 turbo will that column allow it to shift down another gear
83 gmc crew cab
84 chevy blazer
87 r10 short box
Re: Can i use a 3 speed automatic column for a 700r4
« Reply #1 on: April 01, 2018, 09:28:49 pm »
Yes the columns are the same
Offline burnze
« Reply #2 on: April 02, 2018, 05:20:14 pm »
Ok thanks and you were correct
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline square81
« Reply #3 on: April 08, 2018, 07:58:14 pm »
Just wondering do you still have all the detents for the each gear if using a 3 speed column. Being you have one extra gear now. Be nice to know so it will make my search for a tilt column easier. Thanks
« Reply #4 on: April 08, 2018, 10:14:09 pm »
detents are in the transmission.  There is enough travel in the column to work with any TH350 to 700R4 swap
