Author Topic: Tires  (Read 5510 times)
Offline Cheyenne1010
Tires
« on: April 07, 2018, 11:23:45 pm »
I got a 73 c10 long bed,I need to buy some tires and I'm wondering if anybody knows what the Standard size tires came on these trucks.my rim size is 15(looking for Standard width and height) any help will be appreciated thank you guys
Offline Monkey Uncle
Re: Tires
« Reply #1 on: April 08, 2018, 05:16:43 am »
This site says 225/75/R15.  I have no idea if that's accurate.
https://tiresize.com/tires/Chevrolet/C10/
I have 235/75/R15 tires on my 78/85 K10, and they look pretty small, so I might be reluctant to go down to 225's.
Offline 75gmck25
Re: Tires
« Reply #2 on: April 08, 2018, 08:53:23 am »
Tires were not available in metric sizes until about the 80's. It would have been either the old inch sizes (6.50x15) or more likely something  like E78-15.
The repair manual for my '75 has these specs for the C10 tires:
4900 GVW - E78-15
5200 GVW - G78-15
5700 GVW - H78-15
When you look at these older tires, the letter (E, F, H) is a both load rating and size, so the tires get physically larger as the letters go up.   The 78 refers to the aspect ratio (78%), and modern truck radials use a 75 aspect ratio.  However, you can easily cross-reference the old size to a newer one of similar size.  Based on this table, the P225/75R15 is the best match, but I would probably move up to a P235/75R15 because I like the look of larger tires on these pickups http://www.vintagecarconnection.com/vintage_tire_size_conversion_chart.htm.
I use 245/75R16 on my K25, since it is a very common size for truck tires, and nearly the same diameter as my original tires (which were on 16.5" rims).  It is about a 30.5"-31" diameter tire, and there is plenty of clearance in the wheel well.  I think there is similar space in your C10, so you could also use a larger tire if you want to.
Bruce
Offline Rapid Roy
  • Euless, Texas
Re: Tires
« Reply #3 on: April 08, 2018, 11:04:06 am »
My 74 SPID shows G78-15. Cross reference to today's size is 215-75R15. Check link.
Cross Reference Chart
https://www.dbtires.com/crossreference.html
Mopar by Birth
Chevy by Choice
