idle mixture
Topic: idle mixture (Read 9186 times)
markzepp820
idle mixture
March 28, 2006, 05:44:00 pm »
how many turns out is it for a carter quadrajet in a 79' C20 350, th400? And it is stock. thanks
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
idle mixture
March 28, 2006, 05:58:00 pm »
Turn it 2 1/2 turns from all the way in. This will give you a good starting place and, in my case, was exactly where it supposed to be.
SgtDel
George Mason - Final Four
GMU '90
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
Z28 c10
Re: idle mixture
March 28, 2006, 07:25:00 pm »
two and a half turns is a good starting point as the Sarge said, but to make sure, bring the engine up to operating temp, disconnect the vacuum advance and plug the vac source, adjust slowly in till you get the highest idle RPM. If the idle doesn't come up then bring her out till you get the highest idle. Don't go beyond your high idle point, after it's where it needs to be, reconnect the vac advance and idle it back down to 800 revs I believe. From there your set and ready to roll.
JayTater
Z28 C10
1976Scottsdale
Re: idle mixture
March 28, 2006, 09:08:00 pm »
Is this the same for Edelbrock Performer carbs? Mine keeps dying in the morning. It dies twice, always, then it runs fine. I know the vaccuum advance is not working.
Z28 c10
Re: idle mixture
March 30, 2006, 08:57:00 pm »
I'm running an Edelbrock on my 350 and have never had any real issues with it. Check the mixture setting on the choke spring cover( I can't remember the right name for it ). You can turn it clockwise to richen choke mixture or counterclockwise to lean the choke mixture.
JayTater
Z28 C10
DnStClr
Re: idle mixture
April 01, 2006, 09:14:00 am »
Are you sure about that? I think you may have it backwards. As you turn the adjusting screws out, it richens the fuel mix. Turning them in leans it .
Don
87 Chevy Silverado
markzepp820
mixture
April 03, 2006, 08:35:00 pm »
DnStClr is correct on that one
Z28 c10
Re: mixture
April 03, 2006, 08:40:00 pm »
Talkin about the choke spring cover there guys, not the mixture screws. The cover has dash marks on it going from lean one side to rich on the other. At least thats the way my Edelbrock is.
JayTater
Z28 C10
DnStClr
Re: mixture
April 03, 2006, 10:07:00 pm »
OOPs, my bad. Thanks for the correction, Tater. I WAS indeed thinkin about the
idle mixture screws
Edited by:
DnStClr
at: 4/3/06 9:11 pm
Don
87 Chevy Silverado
idle mixture
