Author Topic: 87 4x4 6.0/6l90 swap  (Read 60470 times)
Offline jobobcat18
Re: 87 4x4 6.0/6l90 swap
« Reply #15 on: May 15, 2018, 04:08:37 pm »
What size is the pump outlet?  Probably -6 AN, which is 3/8".  The Pollack valve has 3/8" Feed.  Most sites will tell you that -6 AN is capable of supporting up to 500 hp.
Your 340 lph pump only flows 340 lph at freeflow (0 psi).  It doesn't flow that at 60 psi.  Plus your injectors will only flow so much.
I'm new to fuel systems so please excuse if what I say is incorrect. My goal is to push the engine to about 510-520 hp. Which i believe it can be done with a tune, electric fans, headers, cai, texas speed vvt stage 1 cam, and new injectors possibly. I'm wanting to keep the dual tank so I was looking at the Pollack valve. I have read that the 255 lph pump wouldn't supply enough for over 500. So I was thinking about a 340 lph pump. Do you think my goals here are achievable with the valve or should I go single tank?
Sent from my SM-G955U using Tapatalk
Offline ehjorten
« Reply #16 on: May 16, 2018, 10:50:17 am »
Well...the 2016 Chevrolet Express Van with the Gen IV 6.0 L96 made 342 HP @ 5,400 RPM SAE & 373 lb.-ft of torque @ 4,400 RPM SAE.  It has I think 50 lb/hr flow rated injectors at 58 psi.  That high flow of injectors is for the E85 of the flex fuel programming.  So...the injectors can support a lot of HP, but what is realistic in your vehicle?  You say you think you can make 510-520 HP?
Well...naturally aspirated engines are most efficient in the 0.4 to 0.5 BSFC.  That is 0.4 to 0.5 lb/hp/hr.  If you are making 520 HP then at 0.4 BSFC you need 208 lbs of gasoline.  208 lb of gasoline divided by 8 injectors is 26 lb/hr.  With an injector duty cycle of 80% that equals 32.5 lb/hr injector rating.  At 0.5 BSFC that is a 40.6 lb/hr injector.
Gasoline density is about 6.073 lb/gal, so you need somewhere between 34 and 43 gallons/hr to support 520 HP.  That equates to between 129 to 163 lph, so I don't see where you would need the 340 lph pump, but you have to look at the volume provided at pressure.  Pumps are rated at free flow, so you need to look at the flow curve.  A typical Walbro 255 pump flows about 189 lph at 60 psi and 12 Vdc.  That same pump flows about 227 lph at 60 psi and 13.5 Vdc.
Now, forced induction is less efficient than naturally aspirated.  The BSFC can be up to around 0.75.  That means to make the same 520 HP in an engine that is turbo'ed or supercharged, you would need 390 lbs of gasoline!
My guess is that you are going to be fine with the 3/8" fuel line.  That is the size of the feeds on the Pollack valve.
« Last Edit: May 16, 2018, 10:57:58 am by ehjorten »
-Erik-
Offline jobobcat18
« Reply #17 on: May 16, 2018, 11:29:12 am »
Nice write up my friend. The 510-520 rating I'm estimating is for sure flywheel power. I know the van engine is rated less than the truck's 360. However I could not find a mechanical difference between the engines and I also seen where a boxed tune would give the truck l96 40 hp. That's where I got the number from. This is my first rodeo for anything like this, gotta start somewhere I suppose.
Offline jobobcat18
« Reply #18 on: May 16, 2018, 11:34:41 am »
Another question. Would it be better to run the filter/regulator before or after the valve? I dont mind buying 2 of them if it would be a better option.
Offline ehjorten
« Reply #19 on: May 16, 2018, 01:01:34 pm »
Run it after the valve.
-Erik-
Offline jobobcat18
« Reply #20 on: May 16, 2018, 01:49:37 pm »
Gotcha. I appreciate the help on that.
Offline jobobcat18
« Reply #21 on: May 28, 2018, 05:12:52 pm »
I'm currently reworking my harness and I have ran into a snag. The gmlan wire from the ecm goes to the instrument cluster connector head where the transmission wires go to the chassis connector head. These seem to all go into one thing which goes into the obd 2 port, I am not 100% sure on this. Does anyone know if you could just cut the wires off the head connectors and solder the engine and transmission gmlan wires together and run it to the obd 2 port?
Offline jobobcat18
« Reply #22 on: May 28, 2018, 10:22:19 pm »
Also the tcc wiring to disengage the torque converter. Is that just the cruise/tcc wire that should beveired into a brake switch?
Offline jobobcat18
« Reply #23 on: May 29, 2018, 07:54:35 am »
Be wired*
Offline jobobcat18
« Reply #24 on: July 10, 2018, 08:45:06 pm »
Update:
So far the harness has been reworked as good as I know. The factory fuse block will be reused from the van. I am running with the aeromotive 340 lph  @ 40 psi fuel pumps with aem's wiring kit, they will give me room to grow just incase. Doug thorley tri y headers 1 7/8 tubes. Cold case 87 truck radiator (double pass 1.25" tubes) with fans and shroud from jegs (no external transmission cooler for now). Dirty dingo adjustable motor mounts and ac compressor relocation bracket will be used. Pollack 3 port high psi selector valve will be used after 2 regulator filter combos, one for each tank. I still have more parts to get like fuel lines and fittings and such. But it's starting to come together.
Offline jobobcat18
« Reply #25 on: July 10, 2018, 09:02:52 pm »
Correction, I'll run the aeromotive 340s later. Just going to stick with a walbro 255 until I put the l99 vvt cam from tsp in it.
Offline ehjorten
« Reply #26 on: July 11, 2018, 08:38:18 am »
Hey...I was looking at this thread today...hadn't read it in a while.  I don't know why I missed it for so long...anyways...I noticed that I said to run the filter regulator after the valve?!  I don't know why I would say that.  Maybe I was thinking of the start being the tanks and flowing to the engine.  Anyways...I confused myself.  The filter regulator should be between the valve and the engine.  I noticed that you said you would be running two filter regulators.  I don't see why you would need to do that!
Both tanks feed into the valve.  Both return lines from the valve go back to the tank.  On the outlet side of the valve, that feeds into the filter regulator.
-Erik-
Offline ehjorten
« Reply #27 on: July 11, 2018, 08:43:15 am »
Here is a good place for wiring harness information: http://lt1swap.com/geniv_harness.htm
-Erik-
Offline jobobcat18
« Reply #28 on: July 11, 2018, 09:55:03 am »
The two filter regulators is just one for each tank going into the valve. Since the filter regulator has a built in return I wont need to run the return line in the valve because of this and I'd have to run the filter regulator between the valve and the engine instead of the regulator being between the valve and the tank
Offline jobobcat18
« Reply #29 on: July 11, 2018, 09:56:46 am »
I'd rather have the regulator between the valve and tank anyways, that way I dont have to worry about too much psi being pushed to the valve and busting it. 65 psi limit on the valve and 58 coming out of the regulator is as close as I want to get.
