Author Topic: 87 4x4 6.0/6l90 swap  (Read 60468 times)
Offline jobobcat18
« on: April 29, 2018, 02:30:28 am »
This is my first post and I'm new forums in general. I also tried to post 4 times in tapatalk and just kept getting errors. So if there are numerous posts by my I apologize. I just bought a 2016 van l96 6.0 and 6l90 with the e78 ecm and harness and everything I need running gear wise (I'm not 100% sure what all I need) for 3600 with 3600 miles. To bolt the transmission up to my np208, I'm going to cut the output shaft down and send it off to be cut down and resplined to a 32 spline input for the 208 (I've read how 4 low may not work but I dont use it). Also I have to get the adapter for it. I also plan on keeping my dual tank setup. This is the first ls swap that any of us swapping it have ever done. Any tips would sure be appreciated. And does anyone know how to make the oil pan fit above the front crossmember on a 4x4? Or what oil pan to get? Thanks!
Offline jobobcat18
Re: 87 4x4 6.0/6l90 swap
« Reply #1 on: April 29, 2018, 02:35:27 am »
I will also be updating this post and once finished I will post a full part list for everything I used and done to make everything work.
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: April 29, 2018, 07:59:47 am »
Welcome.
Mopar by Birth
Chevy by Choice
Offline jobobcat18
« Reply #3 on: April 29, 2018, 11:55:35 am »
Welcome.
Thanks rapid!
Sent from my SM-G955U using Tapatalk
Offline Oldblue
  • 1984 C10 SWB
« Reply #4 on: April 29, 2018, 09:11:10 pm »
Yea man welcome!
Old Blue,
One day it'll be restored
1984 C10 SWB
Currently Project: patch panel for bed and body work
Offline jobobcat18
« Reply #5 on: April 30, 2018, 10:17:14 am »
Yea man welcome!
Thanks buddy!
Offline Jason S
« Reply #6 on: April 30, 2018, 02:09:18 pm »
You might check out this thread with a 6.0 LS swap:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=34079.0
Offline jobobcat18
« Reply #7 on: April 30, 2018, 08:26:04 pm »
Will do. Thanks!
Offline jobobcat18
« Reply #8 on: May 01, 2018, 11:54:10 am »
Does anyone know anything about creating a standalone harness for an e78 ecm?
Offline roundhouse
« Reply #9 on: May 11, 2018, 09:04:08 pm »
I did harness  work for mine but it was a 2002 model
And if i had it to do over again I would have some one else do the harness work
You’re going to have to have someone redo the software on the computer anyway
Have them do the harness too
There are cheaper places but I used “Team208motorsports “
Offline jobobcat18
« Reply #10 on: May 11, 2018, 09:21:56 pm »
I gotcha. I would do that but the budget doesnt allow for it. Do you know how to run the ac? Mine is already r134 converted. But the wiring that needs to be done in order for the computer to increase the idle.
Offline roundhouse
« Reply #11 on: May 14, 2018, 09:39:55 pm »
Not sure about the ac idle up
But there is a wire that signals the computer that the ac is on
Not a big deal without it
We don’t have it hooked up and haven’t noticed
It’s a V8 , if it was a four banger you’d need the idle up
Offline jobobcat18
« Reply #12 on: May 15, 2018, 11:15:08 am »
That is a good point. I appreciate it.
Offline jobobcat18
« Reply #13 on: May 15, 2018, 11:22:37 am »
I understand the pollak high psi selector valve (65 psi) can be used to run the dual tank setup. However, can this valve handle a 340 lph pump?
Offline ehjorten
« Reply #14 on: May 15, 2018, 12:16:28 pm »
What size is the pump outlet?  Probably -6 AN, which is 3/8".  The Pollack valve has 3/8" Feed.  Most sites will tell you that -6 AN is capable of supporting up to 500 hp.
Your 340 lph pump only flows 340 lph at freeflow (0 psi).  It doesn't flow that at 60 psi.  Plus your injectors will only flow so much.
-Erik-
