Author Topic: need A/C help now!!!  (Read 17349 times)
Offline Neighbor Beast
« on: April 08, 2006, 05:55:00 pm »
i need ac in my 1987 350 with efi this is the old one
The new one will this fit and work? its form a 1989 chevy with a 350 also
Houston > You
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #1 on: April 08, 2006, 06:06:00 pm »
So what is your question?  Is the compressor not engaging?  Air too warm?  Leak?
SgtDel
Offline 123 pugsy
Re: need A/C help now!!!
« Reply #2 on: April 08, 2006, 08:23:00 pm »
Looks like the belt will track and it would more than likely work.Just don't know what that lump on the front of the pulley does.
Must be a newer improved clutch.
Edited by: 123 pugsy at: 4/8/06 10:11 pm
Pugsy
76 C10 LWB
TPI 350
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
ac
« Reply #3 on: April 08, 2006, 11:43:00 pm »
Yeah, that lump in front is the clutch mechanisms....if it doesnt engage, sometimes a tap on the front of that will engage it...if it is a clutch problem.  I believe the last pic is of an older type.
SgtDel
Edited by: SgtDel at: 4/8/06 10:48 pm
Offline 123 pugsy
Re: ac
« Reply #4 on: April 09, 2006, 07:28:00 am »
Hey Del.You missed 1 sentence between the photos.The bottom is from an 89 and the top one (an 87 is toast).He needs to know if the newer one will work as in: proper size for his 87 system,lines hooking up,charge type........
Pugsy
76 C10 LWB
TPI 350
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
a/c
« Reply #5 on: April 09, 2006, 09:35:00 am »
Ah, thanks pugys...good eye
Yeah, it should work...if the bolt holding the two lines in back bolts into the compressor, and the mounting brackets fit....go for it.
SgtDel
Re: a/c
« Reply #6 on: April 09, 2006, 10:49:00 am »
yea the bolting is the same .thanks for the quick response guy's ima put it on today texas heat is somethign else
Houston > You
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
a/c
« Reply #7 on: April 09, 2006, 12:25:00 pm »
make sure you prime the compressor....w/ the correct oil...i use the dyed stuff --easy to see leaks.
SgtDel
