Author Topic: Rear end vibration  (Read 11020 times)
Re: Rear end vibration
« Reply #15 on: May 20, 2018, 03:15:39 pm »
Is the crossmember in direct contact with the frame or are the spacers between the frame and crossmember?
Offline K20Detroit
« Reply #16 on: May 20, 2018, 03:53:00 pm »
The cross member is in direct contact with the frame. Bolts are tight.
Got the new mounts, but have to get a bolt tonight for it
Offline K20Detroit
« Reply #17 on: May 21, 2018, 05:27:36 pm »
Mounts are in, completely replaced them.
Transmission feels a lot better, maybe a 25% reduction in the vibration, but far from a cure.
Think i will take the blocks out next.
« Reply #18 on: May 21, 2018, 05:41:37 pm »
Try putting the spacers between the crossmember and frame.
Offline K20Detroit
« Reply #19 on: May 23, 2018, 06:59:32 pm »
Moved spacers, it's about 75% better.
I think the spacers might be too thick. Theyre about 1".
I will try measuring angles and use the spicer calc tool. I think a .5" spacer will be perfect.
Offline K20Detroit
« Reply #20 on: May 27, 2018, 04:16:43 pm »
So here is what i have for measurements.
As it sat with the spacers between the crossmember and frame, it was 4d, 4d, 1u.
4 down on trans, 4 down on driveshaft,  1 up on pinion.
That means 0 degree angle on front joint, 3 degree on rear.
Took spacers out, ended up with 0, 6d, 1u.
That was 6 degree on first joint, 5 degree on second.
I played around with spacers and got it to 1d, 5d, 1u. So 4 degrees on both joints.
From what i have read, 3 degrees on all is considered perfect. However, it sounded like if you cant get 3 all around, it was best to get the pinion and trans synced.
Offline K20Detroit
« Reply #21 on: May 29, 2018, 06:52:08 pm »
Update : brake drum was unbalanced. Replaced, smooth as glass until 70mph. Get a rear end vibe at that point. Did not happen on stands. Had it up to 90mph on stands with no vibration.
