Author Topic: Calling all Carburetor Guru's!!!!  (Read 3486 times)
Offline devildogmech
« on: May 26, 2018, 01:17:16 pm »
Ok.... 79 C-10 with a stock 350/350 set up.
Truck is new to me. It came with a gunked up Edelbrock 1406. I tore the carb down and completely rebuilt it. After fiddling with the step up springs it ran like a champ..... For a day.
Over about 20 miles, it went from driving great, to having a little hesitation, to bogging to having a hard time staying running at stop lights, to dying on me at the busiest intersection in town.... After a minuet it started right back up and drove home, stumbling all the way.
If I throw it into park or Neutral, it smooths right out. This made me think its a Trans Issue.... I checked the fluid and the level is ok.... I haven't dropped the pan....
Now I grew up on Honda's... to me Carburetors are black voodoo magic. I rebuilt Cummins 903's in the Marines.... I know engines and Fuel Injection, but not Carb's....
Does this sound like a Carburetor problem or a Trans Problem?  I'm leaning towards a Trans issue, but hey, who knows.
TIA
William
Be good, but not too good.
Re: Calling all Carburetor Guru's!!!!
« Reply #1 on: May 26, 2018, 03:35:35 pm »
could be a many things from carb, timing or vacuum issue.
i would start at the basics and check for vacuum leaks then check your timing and on my truck i set base at 12°-16° then hook the vacuum advance to manifold vacuum not ported like the emissions sticker says
ill also find you some post on the basics of timing and carbs
« Reply #3 on: May 26, 2018, 04:39:11 pm »
Well, I'm an idiot.
I went back and double checked stuff. Turns out the engine ate 2 quarts of oil in about 100 miles. I topped it up and it immediately ran better,...... If i'm LUCKY its valve seals (im not lucky) if not, its rings......
Anyone got a spare 5.3/4l60E swap laying around?
 :o
« Last Edit: May 26, 2018, 04:43:06 pm by devildogmech »
