Author Topic: Idle up solenoid  (Read 7857 times)
Offline Z28 c10
Idle up solenoid
« on: April 12, 2006, 05:48:00 pm »
OK, after finally getting my cam install finished for the second time, I now have an AC issue. My E-brock doesn't have an idle kick up solenoid so I had to idle up to about 1000 before the change, but now I'had to bump it up to about 1300 to keep her from stalling when the compressor kicks in. I was wondering if anyone makes a universal idle kick up solenoid so that I don't have to keep going under the hood between windows down days and hot, need the AC days?
 JayTater
 Z28 C10
Offline 123 pugsy
Re: Idle up solenoid
« Reply #1 on: April 12, 2006, 07:29:00 pm »
Edelbrocks got it.
www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10002&storeId=10001&categoryId=12651&parentCategoryId=10313&langId=-1
Cha-ching.$$$$   I need one also. Haven't hooked up the ac yet but will need the same thing soon.
Edited by: 123 pugsy at: 4/12/06 6:31 pm
Pugsy
76 C10 LWB
TPI 350
Offline Z28 c10
« Reply #2 on: April 12, 2006, 10:52:00 pm »
$82 bucks sounds a little steep, I might try to machine one and/or modify one off of an old Q-junk.
 JayTater
 Z28 C10
Edited by: Z28 c10 at: 4/12/06 9:54 pm
Offline 123 pugsy
« Reply #3 on: April 13, 2006, 04:40:00 am »
I couldn't find an old Q-Jet at the wreckers last time I needed one.Had to buy a new one.
Pugsy
76 C10 LWB
TPI 350
Offline DnStClr
« Reply #4 on: April 13, 2006, 05:28:00 pm »
I don't know if this helps or not,- AC Delco has a compensator kit p/n 17111104 on their website, but it looks like it was only used on Buicks and Olds 307cid and 350 cid diesel engines.
Rock Auto sells it for $61.00. www.rockauto.com
You might try the AC Delco site and do a search.I couldn't come up with anything, but I don't know what yr your truck is..
Don
87 Chevy Silverado
